New Engine, need help with valvetrain noise.
Old Jun 6, 2008 | 11:50 PM
StangLuverJ's Avatar
StangLuverJ
Default New Engine, need help with valvetrain noise.
Hey guys, if you have some time, please help me identify what this noise may be... its a 3.8 with the following:
94-00 Block
[align=left]Eagle 351W forged I-beam rods, ARP rod bolts
Wiseco Forged Pistons - 8.8:1 Compression Ratio (stock bore, 3.830)[/align]CompCam Billet Cam - 218/224 .55/.55 112 lobe separation
1.7 Stud Mount Rocker Arms
SSX Custom Sheetmetal Upper Intake
Ported Polished Lower - IMRC's removed
Ported 1.94/1.56 Stage 3 Heads - Compcam 918 springs @ 135 - SS Valves, 7mm stems
http://www.youtube.com/watch?v=wTARLxFXcps
Old Jun 7, 2008 | 02:04 AM
Stepman's Avatar
Stepman
Default RE: New Engine, need help with valvetrain noise.
Ouch!!! It sounds like "blades" hitting something. Possibly alt or water pump? Do you have a daytime vid? It don't sound like valve train though.
Old Jun 7, 2008 | 07:12 AM
Chopper's Avatar
Chopper
Yep it sounds like it rotational so it has to be waterpump or alternator related.It could be a power steering pump but I would think that would be more,,,muffled.
Go around the engine with a wooden dowel or a long screwdriver and listen to various areas.Watch the belt though.
Old Jun 7, 2008 | 10:56 AM
StangLuverJ
Here you go... No belt...
(the engine has 300 miles on it)
http://www.youtube.com/watch?v=i6j2TD9Awjk
Old Jun 7, 2008 | 05:04 PM
cottoncandymustang's Avatar
cottoncandymustang
yeah i noticed its not a valve train problem. because i noticed when you rev the motor on the video the noise doesnt progress or go away so i think these guys are right either a pully on the assembly is rubbing cause what it sound like on the video is metal to metal just for a test would i would do is while the motor is running take a can of penitrant try to find were the noise is coming from then spray a pully if i stops for about 1-3 secs theres your problem thats just judging from the video
Old Jun 7, 2008 | 09:48 PM
gofastbobby's Avatar
gofastbobby
i'd pull the plugs and see if you have any ptv issues. while you have it down, it may help to do a compression check, you may find that you have a cylinder that is lower than the rest. i missed whether is was mechincal lifters or hydraulic. if it's hydraulic, maybe you have a few that aren't pumping up. with a noise like that coming from that pile of cash under your hood, i wouldn't run it until it's fixed.
Old Jun 7, 2008 | 11:18 PM
StangLuverJ
Hydraulic Lifters...
Old Jun 7, 2008 | 11:22 PM
StangLuverJ
I pulled both valve covers off today and manually primed the oil pump... all 12 rods had oil squirting out from them... Does it really sound like a valve is hitting a piston? If so.. I have driven about 350 miles like that..
Old Jun 8, 2008 | 02:03 PM
Stepman's Avatar
Stepman
I thik you have 2 issues. I didn't hear the same noise in the 2nd vid.Something pulley driven is messed up but in no2, it sounds like a bad starter. There was a part right in the begining when it didn't fire that sounded like the gear kicking the flywheel.
Nick Oliver
Oct 17, 2018 04:22 AM
bjdutch2005
Mar 24, 2017 03:38 AM
MasterLanMan
Sep 13, 2015 08:21 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Emblazoned
Sep 3, 2015 10:45 PM
