oil pressure??
Old Jul 10, 2008 | 12:10 AM
67mustang302's Avatar
67mustang302
Default RE: oil pressure??
Your oil pressure is fine. 10psi per 1,000rpm is acceptable and a good rule of thumb.
Old May 22, 2009 | 10:04 PM
twisted88's Avatar
twisted88
ok its been a while.. i found my oil pressure problem and it was the #2,4,5 main brgs were completely chewed up and gone.. i had motor out and rebuilt.. wooohooo. so a few months latr and a few grand latr im back..its running again sorta.. when warm it just cranks and wont fire. fuel pump runs. i got spark at plugs and i got injector pulse.. i turn ign to run position and the fuel pump keeps running. im lost. i dont know what to do now.. any ideas?
Old May 22, 2009 | 10:08 PM
67mustang302
Are you sure everything is hooked up right? No vacuum leaks etc? Are you sure the timing is correct?
Old May 22, 2009 | 10:27 PM
twisted88's Avatar
twisted88
yea it runs good when cold.. i was just outside and tried to start. it wont start just cranks fast.. fuel pump doesnt shut off when key is in run position car off.. timing is good and no vac leaks ive found..
Old May 22, 2009 | 10:40 PM
67mustang302
Any codes?
Old May 22, 2009 | 11:15 PM
twisted88's Avatar
twisted88
thats another thing. i pulled codes at last build and now i cant get anything.. im stumped.. i followed procedure to get codes and got nothing, even looked it up again and tried no luck. will a fuel pump keep running with key in runposition and engine off if it is failing or failed?
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
wraith777
Sep 28, 2015 10:49 AM
ccdguy
Sep 19, 2015 05:20 PM
SteelerNation82
Sep 16, 2015 07:11 AM
