1995 Mustang Electrical.
Old May 18, 2009 | 02:51 AM
my95gt5.0's Avatar
my95gt5.0
Default 1995 Mustang Electrical.
Hello everyone!
I am in need of some help. I am new to this site and it looks like the best one when it comes to help with your stang, any who....
I have a 1995 Mustang GT, about a month ago I added some "TrickFlow" underdrive pullies, Loved the results!. I noticed that the pullies squeak when im warming up the car and the Battery meter drops when I press on the break. Is that normal? and if so does changing the alternator pulley affect the car battery? I know its supposed to drop your accessories by 25% so do i need an alternator with higher AMPs?
Old May 20, 2009 | 03:49 PM
95greengt's Avatar
95greengt
this is a pretty common problem with ud pullies id say put your stock alt pulley back on and see if that fixes it .....
welcome to mf btw
Old May 22, 2009 | 11:16 AM
my95gt5.0's Avatar
my95gt5.0
yeah, I was thinking of doing that. Do you think i'll loose some HP do to the change back to stock alternator pulley?
thanks again man.
Old May 22, 2009 | 11:40 AM
ewgoetz's Avatar
ewgoetz
If your car is a daily driver than put all the stock pullies back on. I personaly dont believe they are work the trouble for the amount of hp they add. I had installed ud pullies years ago. after a few weeks first issue I had was it started to over heat. Put in a new water pump, temp sensors for the guage and the cpu. It didnt over heat as much but it still came close to over heating. If I turned on the ac it would over heat. than the chargeing system started acting up shortly afterwards. the battery would die out after a hours worth of driving. changed the alt a few times even put in a higher amp. changed the battery a few times when i changed out the alts to make sure the battery werent causing the new alts to fail. I replaced the cables going from the alt to the fuse box and the cabled from the fuse box to the batt. made sure all grounds were secure and corrosion free. Still had the charging issue. They are worth more trouble than they are worth. unless your using the car for the strip only or just driving to the strip than home.
Old May 23, 2009 | 12:06 PM
my95gt5.0's Avatar
my95gt5.0
yeah she's a daily driver. Well it does make a lot of sence, I really appreciate the help. You guys just saved me a whole lot of trouble and a lot of cash, thank you.
Urambo Tauro
Oil and Oil Related Topics
Dec 11, 2017 07:16 AM
Urambo Tauro
Dec 17, 2016 03:30 PM
Urambo Tauro
Sep 7, 2015 12:47 PM
Philhampton1
Aug 21, 2015 12:04 PM
daytooday
Aug 11, 2015 09:22 AM
