start and die
Old Jul 23, 2008 | 11:23 AM
jetmechanic's Avatar
jetmechanic
Default start and die
1978 351M test motor used to test carbs on.
problem motor starts then dies as soon as the starter button is released I know the motor runs good it has just been rebuilt and has about 10 hrs on it and know the carb that is on it is good too.its like you turn off the switch as soon as it starts. BTW battery voltage is 12.7
new rebuilt starter and soelonid
Old Jul 23, 2008 | 03:08 PM
1991LX5.0's Avatar
1991LX5.0
Default RE: start and die
could the distributor have been turned? also i just fixed a friends motor that was acting the same way and he had a large vacuum leak. If the motor was running fine before and will start then die i would start with the basics make sure you have spark, the timing is ok, and good fuel pressure
Old Jul 23, 2008 | 05:28 PM
jwog666's Avatar
jwog666
check to make sure you have bat voltage at the dist. with key on not cranking. if not, your balast resistor in the harness is open circuit. it will fire while cranking due to the resistor bypass wire on the starter, but when you let off the button if the resistor is open you lose voltage to the dist.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
5.0 kevo
Sep 3, 2015 06:24 PM
