where did you mount your MSD ignition box in your SN95
RE: where did you mount your MSD ignition box in your SN95
any empty space you can find.
ive seen somesn95s relocate the battery to the trunk and mount the ignition box on the fender where the battery used to be.
I mounted mine inside the car on passenger side under the dash! beside your break booster you have a rubber firewall grommet you can run quite a few wires thru unless they are your bigger wires! and you can run your wires from there under the plenum to the coil and not be noticable about it!
ORIGINAL: Venomantidote95
good job!
true that, could be but that is what occupies mine! just something i found snooping one day! if you have a stick and that grommet is used for teh clutch cable, you can route the wires thru the doors rubber flex line with teh door control wires and thru the fender on teh driverside, to the coil and battery! just another suggestion, that way if it is in the car teh heat wont kill it and niether wil teh rain if it just so happen to get wet!
Get a load of this. I found a MSD 6AL box in my car...2 months after I bought it I saw a wire or two inside my drivers side front fender. I stuck my hand up in there under the front bumper, and to my surpris I could feel the distinct rectangular heat sinked shape of a MSD box. It was zip tied onto the top of the windshield washer fluid reservoir. Good day for me! Yeah...but I guess that is one place. Lol.
jwog666
12-27-2021 08:09 PM
