1997 GT having problems with d-side door?
Old Jul 30, 2008 | 10:44 AM
EdGe_wannabe's Avatar
EdGe_wannabe
Default 1997 GT having problems with d-side door?
I just got this car over the weekend and I noticed that when the door is completely shut and the window up, there is a crack at the back, top part of the window. It doesn't go up into that channel. Then I went and tried to shut the p-side door and it doesn't do it, it shuts like a charm. However the d-side door when I try to shut it, I have to give it more force than the other side. It seems like it might be 'nicking' the door latch before it actually catches. I've heard these can be prone to this, but I didn't notice it at the time.
Is there anyway to adjust the door to correct this?
Brenton
Old Jul 30, 2008 | 11:43 AM
945LSTANG's Avatar
945LSTANG
Default RE: 1997 GT having problems with d-side door?
is this your second thread on the same exact topic?
Old Jul 30, 2008 | 12:53 PM
EdGe_wannabe
Not really. In the other thread I asked specifically about the windows. This thread is about lining up the door correctly because the body lines are not matching up correctly and it is not shutting properly either.
Brenton
Old Jul 30, 2008 | 01:08 PM
945LSTANG's Avatar
945LSTANG
but its all based off the same problem. a window off track can cause you to have problems shutting the door.
honestly, take off your door panels and check it out.
Doogie65
Sep 6, 2015 02:55 PM
zanemoseley
Sep 6, 2015 12:58 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
SYNY5TER
Sep 2, 2015 01:35 AM
