TSB 05-9-15 MIL AND ETC LAMPS ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRI
THANKS TO Casper98GT FOR THIS TSB!!
Publication Date: April 28, 2005
FORD: 2003-2005 Thunderbird
2005 Crown Victoria, Mustang
2004-2005 Explorer, F-150
2005 E-Series, Expedition, F-Super Duty
LINCOLN: 2003-2005 LS
2005 Town Car, Navigator
MERCURY: 2005 Grand Marquis
2004-2005 Mountaineer
This article supersedes TSB 04-21-09 to update the vehicle lines and model years.
ISSUE:
Some vehicles built 11/29/2004 and prior, may exhibit the malfunction indicator lamp (MIL) and electronic throttle control (ETC) (wrench) lamp on with both P2106 and P2135 diagnostic trouble codes (DTCs).
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using WDS release B36.11 and higher or B37.2 and higher. This new calibration is not included in the B37 CD. Calibration files are also available at www.motorcraft.com. Replace the throttle position sensor (TPS) following the instruction sheet included in the TPS service kit. Clear all DTCs. If the condition is not corrected continue with normal diagnostics
PART NUMBER PART NAME
3L5Z-9B989-AA TPS (Kit)
ISSUE:
ACTION:
bradleyb
11-27-2015 07:50 PM
