To Space or not to Space...
Old Aug 5, 2008 | 11:14 AM
CampStang's Avatar
CampStang
Default To Space or not to Space...
Hey,
I just got a 99 Stang a 3.8, Auto, that is dead stock except for a drop-in K&N filter. I am interested in installing a PowerAid Throttle Body Spacer or like.....
a. What are the pro's and con's to the upgrade..?
b. What brand is the best..?
Thanks
CampStang
Old Aug 5, 2008 | 11:30 AM
51derrill's Avatar
51derrill
Default RE: To Space or not to Space...
Hi:
Throttle Body Spacers rate way up there on the scam list. Their HP gains are ficticious. The most expensive, Steeda. will tell you that, even at $100. they are for cosmetic purposes only. Although they are beautifully machined, with vortex grooves machinedin the ports. you will not see a HP gain. Save your money and buy a tuner,you will get a 15 to 20 gain, some say higher. Also, now that you are moving more air into your engine, you should retune to adjust air fuel movement; a few minutes with a tuner.
Best/ Bill
Old Aug 5, 2008 | 11:57 AM
CampStang's Avatar
CampStang
Thanks Bill for your response...Iheard the same thing from a friend I just needed to confirm that... There's so muchtalk on forums about the bennys of these spacers...It's same old if it sounds to good to be true it usually is.....
Dave
Old Aug 5, 2008 | 02:11 PM
LilRoush's Avatar
LilRoush
You'd get just as much power by picking up a rock in the parking lot and putting it in your cupholder. On a V6 that goes for the spacer AND upgrading the TB itself.
Start with a good catback exhuast... then go from there.
Tivo304
Aug 28, 2023 12:19 PM
cyclop5
Oct 3, 2015 09:21 PM
ponyride00
Aug 12, 2015 01:57 PM
