Window Wont Go Up
Old Aug 10, 2008 | 12:42 PM
945LSTANG's Avatar
945LSTANG
Default RE: Window Wont Go Up
ORIGINAL: *****
thanks alot, but is there anyway of gettin the window up till i can take it to a shop? or is a motor easy to replace with basic tools?
take the window motor out.
pull the window up with your hands.
put the motor back in.
all you need are somebasic handtools.
Old Aug 11, 2008 | 12:07 AM
duche's Avatar
duche
ok hey this is wierd and i really want to know why it did this me and some buddies were drivin it today and after i dropped them off my arm hit the button and it went up, now im really scared to put it back down, i dont think its the motor anymore cuz its up now, but does anyone have any other suggestions on wut it could be?
Old Aug 11, 2008 | 12:20 AM
darryle's Avatar
darryle
i just had this happen to me. it lasted for about 3 months. the window would get stuck and i would hear a click. then the next day it would work. happened about four times. on the fifth time the motor had it. i pulled it out tested it and found it was bad. not sure why it didn't just go bad all at once. but your case sounds similar to mine. hope this helps.
Old Aug 11, 2008 | 10:20 AM
bruehlc's Avatar
bruehlc
The motor contacts wear out and find good and bad contacts. I would advise leaving the window up until the motor is repaired or replaced.
Old Aug 11, 2008 | 11:59 AM
945LSTANG's Avatar
945LSTANG
ORIGINAL: *****
i would invest in a good repair manual and a multimeter to diagnose the problem.
ORIGINAL: bruehlc
how does he even know it is the motor anymore? it could just as easily be something else such as the switch.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
mungodrums
Sep 22, 2015 08:36 PM
wishinsky
Sep 21, 2015 09:48 AM
