Help! 31 spline spider gears?
Old Aug 11, 2008 | 10:41 AM
Quicktime_GT's Avatar
Quicktime_GT
Default Help! 31 spline spider gears?
Simple question..
Can I order 31 spline spider gears and replace my 28's?
It'd be a cheap way to have a 31 spline diff if it'd work. I'd then order me up some 31 spline mosers...
Old Aug 11, 2008 | 11:59 AM
RUDEDOG.357's Avatar
RUDEDOG.357
Default RE: Help! 31 spline spider gears?
I think the 31 spline side gears are way to big for the 28 pline carrier. I have both carriers at work and ill ck it out for you. I was thinking the same thing. Maybe ill try to see if the whole carrier will fit the mustang rear axle.
Old Aug 11, 2008 | 01:34 PM
cobra427's Avatar
cobra427
Yes, you can change out your 28s for 31s in a 9" but the 9 3/8 are all different...
Gary
Old Aug 12, 2008 | 08:56 PM
RUDEDOG.357
I installed 31 spline ford side gears in a 8.8 28 spline carrier and they did fit the carrier but the pinion gears would not go on. I measured the inside of both carriers and the 31 spline is wider where the side gears and pinions go on. the 31 spline carrier seems to be the same width and the 28 spline. maybe install the whole carrier and the 31 spline axles.
Old Aug 14, 2008 | 05:07 PM
Quicktime_GT
Thank you so much.. Thats exactly what I needed to know..
I realllly appreciate it.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
