Wheel Spacers
Old Aug 10, 2008 | 02:24 PM
somdow's Avatar
somdow
Default Wheel Spacers
OK ive come again to be educated. PLease post personal exp or knowledge and not myth....
this is the thing. IM BROKE and for now, i do not plan on getting wider sets of tires because i need more stuff done to the car so any $$$ that comes in, i plan on using for other mods, BUT, i LOVE the wide AGGRESSIVE look of a stang with a wider backend frame.
in general im looking into spacers (not sure i wanna go with this but looking into it) for my car to give it that aggressive power look and not the top heavy wimpy-ish back end look that stock stangs have. like the wheels are hiding behind the tail sorta look lol...anyways
now ive been looking around, and its like everyone's torn about the issue...i cant make heads or tails between fact and myth.
ive heard that because of the wider outset of the tires after the spacers, that the car handles better....um...etc....my car could use better rear end handling. Ive also heard that adding spacers makes understeer worse...that adding spacers adds pressure to important parts of the tire mounts and things can break off...for the most part, ill be street driving and agressive driving when no ones around. i just dont want to power through a turn and one of these things fall off and me BARRELING into a wall...
on the opposite end, ive also heard that ALOt of ppl use em and have no problems...some also have used on the track etc which implies that its ok to use....
i want to hear your FACTS on this seeing as how itll help me determine how to roll. but opinions are fine aswell...please educate sir somdow.
the other ? i have is, when adding the spacers, can i add them to the back end set or does it have to be all 4 tires for stability?
Old Aug 10, 2008 | 04:25 PM
GreyStang's Avatar
GreyStang
Default RE: Wheel Spacers
Spacers on the REAR wheels can work out OK, I would NOT recommend using them on the front, as I've heard a lot of people complaining about weird handling with spacers on the front wheels
Old Aug 10, 2008 | 04:35 PM
2000 G.T.'s Avatar
2000 G.T.
I HAVE THEM ON THE FRONT AND BACK AND I HAVE NO ISSUES WHAT SO EVER.
[IMG]local://upfiles/92494/389652878D5647768760FDA050FF90C2.jpg[/IMG]
Old Aug 14, 2008 | 06:00 PM
1992foxstang's Avatar
1992foxstang
i've got them on my 88 monte ss because my tires needed clearance i couldn't tell a difference on it. they will how ever cause your wheel bearings to wear a little more but as long as you don't get crazy with the size of the spacers you should be fine. i have a set of 15x8 draglites on the back of my stang with very little back spacing and it does look sharp specially with the skinny 15x5's on the front
Old Aug 14, 2008 | 06:37 PM
88Mach1's Avatar
88Mach1
i've got 1 inch spacers on the back of my car. i've had 'em on for about a year and a half now and no problems so far. i even had 'em on at the dragstrip once.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
