torque converter
Old May 14, 2005 | 12:39 AM
gilamonster's Avatar
gilamonster
Default torque converter
how much would a shop typically charge to install a torque converter? or is it something that can be done at home with a lot of work?
Old May 14, 2005 | 11:18 AM
mkspeed26's Avatar
mkspeed26
Default RE: torque converter
yes, you can do it at home without much work. get car way up in the air, remove driveshaft, unbolt tranny crossmember (or mount) and loosen engine mounts while supporting both with jacks. lower the tranny so you can get all of the trany bolts removed. remove the starter. through the starter hole (or if there is a removable section of the tranny plate) remove the 4? nuts that secure the converter to the flexplate/flywheel. disconnect all linkages, sensors, etc that go onto the tranny. slide tranny out. slide converter out of tranny. reverse for assembly. im not sure if you will have to drain ur tranny fluid lines. it depends on it you can get enough room moving the tranny with the lines connected. i havent done this to a stock stang, i have done it to mine (c4 tranny, tiny bit different).
if im wrong, please correct me!
Old May 16, 2005 | 03:59 PM
gilamonster
how high would i need to get the car in the air? i dont have a lift, but i'd rather do it myself to save some money of course.
Old May 16, 2005 | 07:43 PM
89stanglx's Avatar
89stanglx
the higher the better! im sure 4 good jack stands will work.
Old May 16, 2005 | 11:01 PM
mkspeed26's Avatar
mkspeed26
ORIGINAL: gilamonster
just high enough so u can crawl under it and have plenty of space to work and wiggle around. you can easilt get enough space with a floor jack and some jack stands
Old May 17, 2005 | 12:57 AM
gilamonster
this is gonna be off topic, but how much would it cost to get a car re-painted to it's original color. (91-93 lx,94-95 gt) and are more popular paints like black,or silver less expensive than other colors. also, is it cheaper to get it re-painted it's original color or change it to something of your liking (i.e. black,red) i don't want a show-car paint job just something decently nice. around a grand or so.
Old May 17, 2005 | 03:20 PM
mkspeed26's Avatar
mkspeed26
some colors will be more expensive, depending on what its made of. but it wont cost you any more to change the color. call around to local shps to get prices. if u have connections u can usually get one for pretty cheap.
Old May 17, 2005 | 06:05 PM
vfast's Avatar
vfast
I ♥ Acer
if you do this..make sure you replace the transmission front seal and look hard at the rear engine seal....also make sure you lube the seal or 'vertor shaft a tad....replace your convertor bolts with some grade 8 or 10 bolts..look at flywheel for cracks and missing teeth
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
