2nd gear grinding
Old May 15, 2005 | 08:58 PM
IownaMustangNow's Avatar
IownaMustangNow
Default RE: 2nd gear grinding
yea that works... but i wanna be able to shift fast
Old May 16, 2005 | 09:21 AM
Djs94stang's Avatar
Djs94stang
Ok first of all the TSB mentioned is not for your car. It's for the 99 or 00 to 2003 models. It is definitely your second gear syncho and a rebuild is needed. This is true especially if it shifts fine at low speeds. The higher the rpm you try to shift at the more the synchro has to work. It will get progressively worse whereas you won't be able to shift even at low speeds. Few choices; you can buy a kit for $250 or remove your trans yourself and take it somewhere and you will probably pay around $400 give or take. If you have the whole job done including removal and install it'll run you anywhere from $1200 to $2000 depending or where you go.
Old May 16, 2005 | 10:41 AM
nanaki's Avatar
nanaki
Retired MF Moderator
ORIGINAL: jchittick
Do a search on this, it is a HIGHLY talked about subject. There is a Ford TSB out there for it.
Well-started typing before I saw that you has a '96........I'm talking about the newer transmissions......sorry......
where do i find the info on the TSB? i want to have mine redone before i get my blowr on, cause i know they won't touch it when i put that on. my dealership are arseholes about any type of warranty work. so i need to go in there with the TSB info in writing before they'd even consider doing it.
Old May 16, 2005 | 03:05 PM
Djs94stang's Avatar
Djs94stang
There was a lot about a month ago on the 4.6 forum regarding the tsb. I tried to do a search to find it but the search didn't seem to work. I think it was 99 to 2003 or maybe 2000 to 2003 model years. The tsb is for replacing the synchros.
Old May 16, 2005 | 03:16 PM
jchittick's Avatar
jchittick
ORIGINAL: nanaki
https://mustangforums.com/m_516455/m.../tm.htm#516455
Try it here, i thought there was a different one, but maybe not......
I've also seen a website where you can get the official info, let me try and find that also......
http://forums.modulardepot.com/showt...threadid=32640
Old May 16, 2005 | 09:48 PM
racer02GTstang's Avatar
racer02GTstang
ive got it where my car will grind going into second gear with my foot all the way down to the ground on the clutch. my friends all laughed at me when i grinded trying to get into 2nd this one time. it happens about every few weeks on me. with my mods, the ford dealer shouldnt make me not be able to get the work done, can they not accept me cause i got a new shifter?
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
