Cllicking noise from tire
Old May 19, 2005 | 02:11 PM
99saleen351r's Avatar
99saleen351r
Default RE: Cllicking noise from tire
ORIGINAL: Djs94stang
You have drum brakes correct? If so, it would be the self adjuster has come loose or parts of it has.
Drum brakes on the front of a stang......Not since the sixty or seventys
Old May 19, 2005 | 02:13 PM
C/Note's Avatar
C/Note
I ♥ Acer
do you have hub caps ..?? [&:] or loose center caps ..???[&:]
Old May 20, 2005 | 12:03 AM
DaGGer's Avatar
DaGGer
ok well its not anything in the tread of the tire...so i'm thinking its something inside the wheel....it might be say something wrong with worn brakes...who knows....but i'm going to be doing the brakes probably this weekend...so i will check everythinjg out then
Old May 20, 2005 | 01:04 AM
DaGGer's Avatar
DaGGer
i'm pretty sure its from the pads being pretty worn...buti'm going to replace them and maybe the rotors depending on what the wear on them is..i also have to get my radio installed again...i broke it so i have to ship it back...then there is the noise from my engine but i know what that is...then there is my door...yea there is a lot of **** to fix...i think that i'm going to have to put off my turbocoupe project but ...i guess i need to have a nice car that has everything working before i swap out the engine and trans and ****...
jwog666
Dec 27, 2021 08:09 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
69Volunteer
Sep 30, 2015 10:39 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
