Sponsored by:
Sponsored by: DashLynx
anti freeze in the block
Old 09-26-2008, 08:05 PM
kdobson
kdobson's Avatar
Default anti freeze in the block
I have a 302 boss and I just changed the intake manifold gaskets. I'm afraid some antifreexe got inside the block. I changed my oil and filter before trying to fire it up. When I started it huge clouds of white smoke kept cooming out of the pipes. Is it possible all the antifreeze did not get out or should I be looking at something else. If there is still antifreeze in the block what do I need to do to get rid of it?
kdobson is offline
Old 09-26-2008, 10:11 PM
UTI_TECH429
UTI_TECH429's Avatar
do you get this white smoke all the time now?
UTI_TECH429 is offline
Old 09-26-2008, 11:27 PM
kdobson
kdobson's Avatar
after I changed the oil and started it up, I ran it for about 5 minutes with huge white clouds pouring out. I shut it off and started it up again about thirty minutes later and got the same thing.
kdobson is offline
Old 09-27-2008, 03:56 PM
UTI_TECH429
sounds like alot of moisture in the system
Old 09-30-2008, 01:09 PM
ChalknCover
Sgt. Killjoy
ChalknCover's Avatar
Default Problem should be solved
I just did a Ford F-series truck that had the same problem, there may still be anti-freeze in the oil pan. You need to just flush oil into it and then drain it again, or just take the pan off and make sure it is clear, then refill it to specs and see if it does not go away after a couple minutes of running. If not, or there is still an ungodly amount of anti-freeze in the motor, either the gasket you installed is no good, or there may be a bigger issue present.
ChalknCover is offline
GimpyHSHS
19
12-19-2023 01:12 PM
BOB ROME
07-26-2023 01:54 PM
mustangheaven
01-03-2016 11:20 AM
Matt's 95 Stang
10-05-2015 07:16 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: anti freeze in the block
