BBK Long Tubes (4.6)
Old May 22, 2005 | 01:20 AM
BMFMUSTANG's Avatar
BMFMUSTANG
Default BBK Long Tubes (4.6)
Need advice for installation. Instructions state: lift motor 3-4 inches to install. Is there a way to install w/o lifting motor. I know it's tight, but there has got to be a way. If there are any links out there to your personal experiences installing these, please send me the link. Thanks
Old May 22, 2005 | 01:46 AM
94Cbra's Avatar
94Cbra
Default RE: BBK Long Tubes (4.6)
I think the only other way is to drop the K member. Raising the motor isnt that bad, prolly be a lot easier.
Old May 22, 2005 | 02:37 AM
99saleen351r's Avatar
99saleen351r
Lift the motor.Theres not enough room other wise!When they tell you that usually its cause thats what you need to do,I know your a guy and don't follow directions but its the easiest way
Old May 22, 2005 | 12:36 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
You will need to lift the motor, it's no big deal just put a jack under the oil pan(with a peice of wood to help ditribute the weight)unbolt the engine mounts and lift the motor. It will save you time and a ton of frustration to jus tdo it the right way.
Jb145700
Aug 21, 2022 06:37 AM
Luke9222
Oct 22, 2015 11:55 PM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
BrantleyS550
Sep 14, 2015 04:18 PM
