Speedometer Drive Gear Question
Old May 22, 2005 | 06:59 PM
BerlinKid's Avatar
BerlinKid
Default Speedometer Drive Gear Question
I have an 87 GT convertible 5.0 manual tranny with 65K on it. The speedometer and cruise control no longer work. OK, thought that I needed a new cable...pulled everything out and cable is OK. Removed cruise speed sensor & cable from tranny and everything rotates up to the speedometer. Seems to me that the drive gear in the tranny is FUBAR. Is this a common occurrence? or is my diagnosis all wet?
If I am correct, the tranny has to be dropped to replace the gear which methinks will be very expensive.
Any thoughts????
Old May 23, 2005 | 08:51 PM
C/Note's Avatar
C/Note
I ♥ Acer
Default RE: Speedometer Drive Gear Question
your speedo works ....??????[&:] but no cruise..?
Old May 23, 2005 | 10:20 PM
BerlinKid's Avatar
BerlinKid
Speedo and cruise doesn't work at all. When I remove the driven gear/speedsensor/cable assembly from the tranny, I can turn the gear and the speedo moves indicating that everything from the speedo to the driven gear operates. I therefore conclude that the drive gear in the tranny is bad. This really seems strange to me and was wondering if anyone else had ever had this happen? Seems like it will be an expensive repair.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Figure8allday
Aug 22, 2015 11:11 AM
Mnuckolls
Aug 9, 2015 08:54 AM
dfw692
Aug 7, 2015 11:53 PM
