Is it the brakes?
Old Oct 10, 2008 | 07:57 PM
SlvrOhTwoGeeTee's Avatar
SlvrOhTwoGeeTee
Default Is it the brakes?
When I'm braking I get a pulse in the pedal and a vibration in the steering wheel. I have heard it could be a warped rotor or possibly a tie rod end. Is there a way to tell which it is without replacing them? When I am driving I don't have any vibrations at all, it is strictly under braking. Thanks in advance.
Old Oct 10, 2008 | 09:20 PM
forcefeed's Avatar
forcefeed
very simple to determine, take a dial indicator and measure the brake rotor run out. Based on your description of the problem Im pretty sure its your front rotors, you would have 2 options, the first is to replace them, the second if there is enough material remaining you could have then machined and reinstalled
Old Oct 10, 2008 | 11:02 PM
Blckstng93's Avatar
Blckstng93
Its one or both of the rotors. Replace or turn both at the same time of course. A dial indicator is best...if you have one. Sometimes you get lucky and can tell by looking at the rotor head-on as it spins, or you can hear faint rubbing in some spots as it rubs the pad. Sometimes.
Old Oct 10, 2008 | 11:04 PM
volcomchester18's Avatar
volcomchester18
yeah turn your rotors and get new pads. Easy inexpensive job.
Old Oct 11, 2008 | 03:34 PM
SlvrOhTwoGeeTee
thanks for the input everyone I really appreciate it. I think I will just use this as an excuse to upgrade the brakes now :-) Thanks again
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
