Six Speed Swap???
Old May 23, 2005 | 02:34 AM
New2Ford's Avatar
New2Ford
Default Six Speed Swap???
I am not shure if this is the right place to post this,so mods please move it if necessary.
I am going to buy a mach 1 soon and wanted to know if I can swap a six speed trans into it? If so what will I need to make everything work? I can do major fabrication,but if I could get away without having to fabricate-that would be my first choice.Is there a specific tranny that is better than others? Just need some input!
thanks
N2F
Old May 23, 2005 | 03:35 AM
primetime5.0's Avatar
primetime5.0
Default RE: Six Speed Swap???
all you need is a different bell housing,tranny, and a driveshaft. as well as a clutch flywheel and other parts im not remembering
Old May 23, 2005 | 03:49 AM
New2Ford's Avatar
New2Ford
So basically its just a bolt in and a (shorter/longer)driveshaft? Does anyone sell a kit?
thanks
N2F
Old May 23, 2005 | 05:07 AM
primetime5.0
check D&D http://www.ddperformance.com/
Old May 23, 2005 | 12:49 PM
New2Ford's Avatar
New2Ford
Awesome,thanks Do the machs have elc. speedo or mechanical?
N2F
Old May 23, 2005 | 07:04 PM
DaMach04's Avatar
DaMach04
The speedo is Mechanical i think....It is NOT digital. I have a Mach. And yes you can swap out your trans. with the Cobra (so im told by the dealership) But you must wait untill your warranty is up or else it will VOID it.
Old May 23, 2005 | 11:32 PM
IWinULose's Avatar
IWinULose
ORIGINAL: New2Ford
N2F
Computerized speedo... no 'lil speedo gears in the newer ones...
Old May 24, 2005 | 12:16 AM
Phillyblunt474's Avatar
Phillyblunt474
ORIGINAL: IWinULose
ORIGINAL: New2Ford
N2F
Correct thats why when you get new gears you reflash to correct your speedo
mungodrums
Sep 29, 2015 09:18 PM
musnicki
Sep 23, 2015 07:11 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
jaiidutch
Sep 14, 2015 10:29 AM
vintageaion
Sep 8, 2015 10:45 AM
