hypereutectic vs. forged
Old May 25, 2005 | 02:40 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: hypereutectic vs. forged
Be realistic when you answer. What are your performance goals? If you are going for a mild rebuild the Hyp. pistons are fine, if you want room to grow down the road go forged. Yes a forged piston is stronger, and take alot more abuse, but they can fail, but when they fail they tend to melt or bend where a Hyp. piston tends to crack or break. Both are bad situations but givin the choice I would rather melt a hole in a piston than have one break apart.
Old May 25, 2005 | 02:49 AM
91stang's Avatar
91stang
what i want is a nice daily driver car that's fun to drive but i can take to the strip once in a while and do a lil damage
Old May 25, 2005 | 03:02 AM
JD1969's Avatar
JD1969
If you don't ever plan to spray it go hyp. and put the money you save to other uses, but if you think you might ever put some n2o on the car do yourself a favor and put in the forged parts while it is apart.
Old May 25, 2005 | 09:13 AM
crower's Avatar
crower
forged pistons (Areas units) I had on my 454 annoyed me in daily drive while the car felt downright terrible before it was warmed up. So I reccomend hyper pistons for a car that will be used everyday. Forged pistons are very good for all kinds of performance upgrades and a must when running forced induction or NOS.
Old May 25, 2005 | 12:35 PM
fordguy17's Avatar
fordguy17
110,000 miles is really not that much. why rebuild? is it smoking or burnin oil. if it runs fine just leave it. i have 128k and many others have much more than that with no problems. the 5.0 is a stout motor.
Old May 25, 2005 | 10:43 PM
91stang's Avatar
91stang
well another reason for wanting to rebiuld the engine is cause i was told that if i wanted to drop a cam in there then it'll be better to rebiuld the whole thing. any thoughts about this?
Old May 26, 2005 | 04:12 PM
1fststang's Avatar
1fststang
forget the rebuild and stroke it out 331 347 big power u wont be disappointed
NorthAmericanTuning
Nov 9, 2016 11:44 AM
JT76
Sep 20, 2015 11:32 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
FD725
Aug 11, 2015 03:43 AM
