swap question
Old Nov 3, 2008 | 07:32 PM
95v6eR's Avatar
95v6eR
Default swap question
hey guys quick question here but would like some good imput. i got a 95 v6 stang. i was thinking about doing a v8 carburator swap in the car. i was thinking about using the the 351w or a 302. would it be worth my while doing this since its only gunna be summer weekend car anyways. thanks for any input
Old Nov 5, 2008 | 08:04 AM
LilRoush's Avatar
LilRoush
Go read in the V6 section for a bit on this topic. You'll quickly learn that you can make more power cheaper and easier by building the V6 rather than swapping in a V8.
Old Nov 5, 2008 | 03:20 PM
ExtrmZ's Avatar
ExtrmZ
i would say consider building up your V6, before you do the swap
Old Nov 5, 2008 | 06:45 PM
95v6eR's Avatar
95v6eR
alright thanks, but the way i was seeing it, its going to cost me more to build a v6 than build a v8. either way i know how to work on cars so either one is an acceptable idea
Old Nov 6, 2008 | 06:37 AM
GreyStang's Avatar
GreyStang
Yea but before you can start 'building' the V8 you first need to go through the expense of installing it along with ALL the other bits & pieces the V8 needs..
If you can get a V8 cheaply and are eager to do the swap then go for it, especially if you can do the work yourself.
For other people who would have to hire a garage to do the swap, the conversion wouldn't be cost effective at all.
Old Nov 6, 2008 | 02:06 PM
LilRoush's Avatar
LilRoush
If it costs you more to build a V6 than a V8 you are doing it wrong.
What numbers did you use to get that conclusion?
Old Nov 7, 2008 | 01:01 PM
ExtrmZ's Avatar
ExtrmZ
you should be able to get some decent power out of the V6 for cheaper than building a V8
Old Nov 8, 2008 | 05:10 PM
95v6eR's Avatar
95v6eR
i got the car cheap an clean. and the way im lookin at it and not numbers is if you have the same build on a v6 compared to a v8, the v8 is going to make more power. as it is i know where i can get a 351w for cheap and already has some parts on it.so money wise theres your answer
04stangman
Sep 17, 2015 01:45 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
jaiidutch
Sep 14, 2015 10:29 AM
97SN95GT
Sep 13, 2015 09:45 PM
