wheel allignment
Old May 28, 2005 | 02:01 PM
Scooterman's Avatar
Scooterman
Default wheel allignment
i need some advice.. hopefully u guys can give it to me.. when ur steering wheel allignment is wrong it affects ur steering right.. if im wrong then please correct me... tell me what happens when ur wheel allignment is wrong and what changes after u get it fixed..
Old May 28, 2005 | 02:30 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
Default RE: wheel allignment
it's not really the steering wheel they align. It's caster, camber and toe....or the angle of your tires in relation to you steering.
Unless you have caster/camber plates, there is not much room for adjustment on 99+ mustangs (i don't know about other models). Mostly, they will just adjust your tie rod endsso the tires are straight and aligned with each other.
Old May 28, 2005 | 02:42 PM
cammedlx's Avatar
cammedlx
they also make sure you're steering wheel is straight, and you don't really need caster/camber plates,just grind the strutstrust me i know i do them 6 days a week
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
