Non Functioning Driver Window
Old Nov 18, 2008 | 04:28 PM
Kikandross's Avatar
Kikandross
Default Non Functioning Driver Window
OK here it goes.
My driver window was working fine until today.
Now it is not working. Can anyone help?
Old Nov 18, 2008 | 08:44 PM
Blckstng93's Avatar
Blckstng93
Im guessing its power windows?
Does the motor make noise like its working? If no than the motor is probably shot, or you may just have a loose/corroded connection. Youll need to remove the door panel to check. Does the passenger side work? If not than you have a bad switch. Just to be sure grab a test light and test the switch for power when you press the button. Then test the wires at the motor when you press the button.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
TCStangerv6
Oct 11, 2015 05:57 PM
breaking
Oct 2, 2015 01:27 PM
