Burn out
Old May 29, 2005 | 05:19 PM
yeayea0's Avatar
yeayea0
Default Burn out
I just bought my first stickshift Mustang this week and this may sound like a stupid question but how do I burn out with it?
or Does anyone have any other tips or tricks I can now do?
Thanks alot,
Jon
Old May 29, 2005 | 06:31 PM
Aixtreme89's Avatar
Aixtreme89
Default RE: Burn out
Well you can do a burn out by reving up your engine and then dumping the clutch. Like at around 3000-4000rpm. You can also do a line lock by doing the same thing, but in addition you hold down the brake with your left foot while you give it gas. You can do a burn out in 1st or 2nd. But I could only do a line lock in 1st. But then again I bet if I dumped the clutch at 5000rpm I could have gotten the tires to keep spining, but I dont want to abuse my car that much.
Old May 29, 2005 | 09:51 PM
dc_mann8's Avatar
dc_mann8
put the heel of ur right foot on the brake, and ur toe of that foot on the gas.. use ur left foot on the clutch.. hold down the brake.. push some gas in and let the clutch off.. voila
Old May 29, 2005 | 10:11 PM
Sergey's Avatar
Sergey
has anyone burned out with an automatic before?
Old May 29, 2005 | 10:16 PM
Phillyblunt474's Avatar
Phillyblunt474
ORIGINAL: Sergey
Not in my stang but ive done i in my buds bimmer, simple as pushing the brake and the gas at the same tiem and finding the right amount for each to not move and to keep the back tires spinning if your trying to do a brake stand
Old May 29, 2005 | 11:31 PM
Sergey's Avatar
Sergey
i was thinking about putting it on neutral and going up to about 4000rmp and then quickly changing it to D(drive)
but most likely i'm going to break something that way
Old May 29, 2005 | 11:36 PM
stngman00's Avatar
stngman00
Sergey, I don't reccomend doing that. Good way to mess up your transmission. I have an automatic and when I want to do a burnout, I just hold the brake and nail the gas, then just let up off the brake enough to hold it there but keep the tires spinning.
Old May 29, 2005 | 11:49 PM
Black Snake's Avatar
Black Snake
Yeah its simple to do a burn out with a stick if you want you can rev it up a bit and hold the brake, but with me all I have to do is press down the gas and the tires will go solo, but I can never do a brake stand no matter how hard I hold the brake.
Old May 30, 2005 | 12:34 AM
DaGGer's Avatar
DaGGer
burning out in a standard is easy...just rev up and slide your foot off the clutch so it sort of pops so you can get the tires to spin easy...then you can pt that foot on the brake and make a nice smoke show...or do the heel toe to do a burnout but thats a little more difficult...doing a burnout in an auto is easy...just brake and gas...the 4 cylinders cand do it because i have and am driving one right now...
Old May 30, 2005 | 01:06 AM
92hatchLX's Avatar
92hatchLX
In my auto, if I am having trouble getting the powerbrake goin, i punch the gas and then right after that step on the brake at the same time that'll do the trick too.
