Starts but won’t run
Old Nov 4, 2003 | 01:01 AM
67aquafastback's Avatar
67aquafastback
Default Starts but won’t run
It could be the buzz in my head from all those beers and damm I just remembered there is no bee's nest in my yard.</P>
CHECK THE FUEL PRESSURE !!! DO AS YOU ARE TOLD. let us know what you come up with. normally a tps will not go out all the way they will devlope a open in certian spots causing a hesitation.</P>
Old Nov 4, 2003 | 10:59 AM
tripsevn7's Avatar
tripsevn7
Moderating with Angels
CHECK YOUR TPS SENSOR. </P>
Old Nov 4, 2003 | 11:29 AM
95Stealth302's Avatar
95Stealth302
Yeah you might have a bad TPS where your getting way too much fuel, or really bad timing.
Old Nov 4, 2003 | 02:03 PM
johnc's Avatar
johnc
Originally Posted by VLXMan
Thank's Guys...</P>
I do hear the initial Fuel Pump loading (buzz?) when I turn the key.......... it starts from the fuel sent by the fuel pump, but it's not constent enough to keep it running? It there even a chance that I could be on track here?</P>
Thanks - VLXMan</P>
</P>
I think you may be on to sumthin, isn't there an input required from the oil pressure sensor to keep the fuel pump running? Cranking the starter bypasses the sensor so the engine can start, then the pump stays on when the oil pressure comes up? This is the way it worked on 2 other cars I know about.</P>
Old Nov 11, 2003 | 01:52 PM
johnc's Avatar
johnc
Hey VLXman, did you find out what it was? Us armchair mechanics want to know!!</P>
Old Nov 13, 2003 | 12:37 AM
VLXMan's Avatar
VLXMan
Sorry for the delay. Yes, it appears that the problem is the Fuel Pump. So, it will be awhile before I will get it fixed. I'll post again when I have it running.</P>
Thank you all for your input.</P>
VLXMan</P>
djbigskrilla
Sep 20, 2022 01:04 AM
bryan616fl
Jan 25, 2019 09:07 PM
1987gt40ttopt
Aug 28, 2015 10:49 PM
jjwinel78
Aug 17, 2015 03:34 PM
89blueslug
Aug 10, 2015 07:20 AM
