spark plug hole stripped!!!!
Old Nov 29, 2008 | 07:06 AM
abingdonmustangs08's Avatar
abingdonmustangs08
Default spark plug hole stripped!!!!
Last night i noticed a ticking noise, sounded like a slight exhuast leak. Then around 9:00pm i was leaving a freinds house to come home and when i started it it was much worse. So i got under the hood and looked, found that on of my spark plugs was loose. I have a 2002 GT so i have the coil packs on each plug, the noise was the gas coming out of the plug. When i tried to put the plug back in i noticed the threads on the head are stripped. Any ideas on what i should do. I was thinking about tapping new threads in.
Old Nov 29, 2008 | 08:16 AM
awakeinAZ's Avatar
awakeinAZ
I don't think you can do that without taking the head off. Metal shavings will fall into the cylinder. You won't be able to do that by hand anyway. Recommend you find a wrecked car and swap the head out on that side.
Old Nov 29, 2008 | 10:24 AM
USMC1775's Avatar
USMC1775
It depends how stripped it is.. If the entire thread is gone, some would JBweld it and tap that.
Any way you look at it, its best to remove the head, and Id say take it to a mac shop
Old Nov 30, 2008 | 06:09 AM
abingdonmustangs08
yeh, I know i have to take the head off, was just woundering If anyone had any differant or better ideas, thank's for te heads up. I should be able to just go over the old threads, from what i can see they aren't completley gone. Thank's again guys.
Old Nov 30, 2008 | 08:55 AM
BruceH's Avatar
BruceH
Delete with a bad attitude!
Old Nov 30, 2008 | 06:56 PM
TOOT's Avatar
TOOT
The exact same thing happened to me this Wed. Tapping sound that sounded like a exhaust leak then a pop, puff of smoke and a coil bobbing up and down.
There are three recommended repairs that I found but wanted to know opinions on them.
1) Helicoil
2) time-sert
3) Calvan spark plug installer kit
Old Dec 11, 2008 | 02:10 PM
COBRA1994's Avatar
COBRA1994
I HAVE REPAIRED SEVERAL OF THESE WITH OUT REMOVING HEAD USING TIME SERT HOOK OR TAPE HARD PLASTIC TUBE [PIECE OF HARD VACUME LINE] TO SHOP VAC TO REMOVE PARTICLES FROM CYLINDER AND HAD NO PROBLEMS OR COMEBACK ISSUES. GOOD LUCK
Old Dec 11, 2008 | 06:21 PM
68dustin's Avatar
68dustin
it has happend to me as well... its a pretty common thing with the ford cars and ford trucks. i had a 2002 f-150 with the 5.4L and it shot the #1 spark plug out.. the shops wanted 1200 to fix it. I ended up buying a $40 spark plug heli coil and tap set. Just read up on it a little and hook up your shop vac and tap and heli coil it... it worked great for about 6 months then the cylinder across went out. after the other cylinder went out, i fixed it and traded it in for a dodge!
Old Dec 11, 2008 | 06:47 PM
koolkat13838's Avatar
koolkat13838
lol^^^
Old Dec 11, 2008 | 06:56 PM
Tim37's Avatar
Tim37
i hope your joking
heli coil first but
anyway if you have to pull the head send it to a machine shop and have steel inserts put in.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
GLOCKer
Sep 28, 2015 07:36 AM
