V6 or V8
Old Dec 10, 2008 | 10:37 AM
  #251
LilRoush's Avatar
LilRoush
Not if i swap my ported M112 back on for the weekend! If I just write SVT on the front next to the snout, how many people would realized I switched from a black M112 to a Whipple anyway??
Old Dec 10, 2008 | 06:22 PM
  #252
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
lol im sure none of us would notice
Old Dec 10, 2008 | 09:35 PM
  #253
mustangman02232's Avatar
mustangman02232
sorry, cant help it
"Lurking below the 301-inch modular in an HP Performance twin turbo kit with 57mm turbos. Shoving 15 pounds of boost into the Bullitt intake manifold and Patriot Performance heads generates 602 rwhp and 615 rwtq"
http://www.turbochargedpower.com/Carter%2001%20GT.htm
"Congradulations to J's new dyno numbers making 610rwhp and 570rwtq at 5800 rpms 16 psi. J is currently running the version 2 twin turbo kit layout. Running twin gt30r .81 turbine a/r ball bearing turbos. Dual 3" exhaust dump pipes and 3.5" intercooler pipes. Here is a link to his dyno vids. Right click save as "
http://tmaturbo.com/
Old Dec 11, 2008 | 02:47 PM
  #254
LilRoush's Avatar
LilRoush
Yep, to add to that, Gary made 660rwhp on only 15 psi with his V6 as well. Just goes to show the v6 can really flow when built right. But then what do we know.... we own the wrong motor right?
Old Dec 11, 2008 | 02:56 PM
  #255
NYstang's Avatar
NYstang
MF Staff Snitch
Theres a reason my sixxer is project "You're doing it wrong"
Old Dec 11, 2008 | 06:49 PM
  #256
koolkat13838's Avatar
koolkat13838
^^^ I like the name. I think it is perfect
Old Dec 11, 2008 | 06:54 PM
  #257
03sixbanger
Ryan's Backup Mod
i usually look at mine and say "but its still a six"
Old Dec 13, 2008 | 10:11 PM
  #258
Fobra's Avatar
Fobra
Banned
I know what your saying, and thats a hot v-6... however you have to acknowledge that a v8 with the same build (which is just about the same cost) would be making substantially more power, apples to apples
Old Dec 13, 2008 | 11:06 PM
  #259
mustangman02232
ummmm, only differance was the v6 was on stock ported heads
Originally Posted by mustangman02232
sorry, cant help it
Old Dec 14, 2008 | 01:42 PM
  #260
LilRoush's Avatar
LilRoush
Not a chance that the V8 at that power level is the same cost. Six of everything instead of 8 in the bottom end... and the V8 would also require aftermarket crank and block - which a V6 uses the stock Ford parts for. And look at the numbers. The V6 cars where using similar PSI levels and making the same (if not more) power. Numbers don't lie (in this case).
