Couple of basic mechanical problems
Old May 31, 2005 | 10:53 AM
ckthecerealkiller's Avatar
ckthecerealkiller
Default Couple of basic mechanical problems
I am not sure what these could be. But I am 17, the only things I know about cars I taught myself. Plus my father is no help right now.
1. When I go to shift from first to second I will sometimes hear this popping noise. It is so loud it sounds like a big rock is flying up into my front left wheel well. I also hear it when I accelerate quickly in first or second.
2. My front left wheel also will sound like it is flat. But the car doesn't curve in any way. Perfect alignment. I will just hear this constant really quiet thud when it hits one spot of the wheel. I looked at the wheel nothing is wrong with it....
3. Lastly, sometimes when I make a right turn, if I am near a wall that will deflect sound, I hear the squeaking sound. It isn't my brakes, well cause I am not on my brakes. I checked the bearings, rotors, everything that could be doing that. Nothing.
Any help would be greatly appreciated. If you tell me what's wrong I know a few people that would help me out. People other than my very busy father.
Thanks in advance everyone!!!
Old May 31, 2005 | 11:58 AM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: Couple of basic mechanical problems
Get your car up on jackstands and spin the wheel and try to find the squeek, It sounds like it IS a wheel bearing or your brakes.
What do you mean it makes a thud on one spot on your wheel? Elaborate some more on that.
As for shifting, have you jacked your car up and checked your tranny mount?
Old May 31, 2005 | 12:28 PM
ckthecerealkiller
As for the wheel, it sounds like there is the sticker that comes with a new tire on it. Like there is this huge hump on the wheel. I don't feel anything when I am driving it. I only hear it.
I'll check the mount sometime today. I don't have anything to do but take my friend to work.
Old May 31, 2005 | 12:53 PM
Chopper's Avatar
Chopper
The wheel problem could be the beginning of a tread separation,potentially dangerous.Have a knowledgeable tire shop check this.The other things should show signs of contact between parts and should leave shiny marks on each other.Get the car up in the air and have a helper push in the clutch and move things around inside the car while you look and listen from under the car.Use jackstands,don't even think about trusting your life to just a jack.
Old May 31, 2005 | 02:00 PM
Djs94stang's Avatar
Djs94stang
Check the motor mounts for the noise while accelerating or shifting. Check the tie rod ends/ball joints for the squeaking.
Old May 31, 2005 | 10:38 PM
BlackMage's Avatar
BlackMage
Check your tie rod ends on both sides, i had a weird squeak on mine, had a mechanic look at it, couldnt diagnose it, then the very next week broke my tie rod end, i would replace those anyways because they are not greasable, unless they have already been replaced
Luclin999
Sep 7, 2015 11:33 PM
CarrieS
Sep 1, 2015 01:00 PM
Cin K
Aug 31, 2015 07:31 AM
Itstbrown
Aug 9, 2015 03:49 AM
