speedometer going crazy!
Old Dec 12, 2008 | 01:13 AM
guitarguy841's Avatar
guitarguy841
Default speedometer going crazy!
i have a '92 2.3L LX and something is wrong with the speedometer. every once in a while it will jump up to like 110mph when im actually going 35. it sounds like something is like rubbing or catching in the dash right behind the needle. does anyone know whats up and how much it will cost to fix if i do it myself.
Old Dec 13, 2008 | 02:33 PM
Timspony's Avatar
Timspony
SVT Section Moderator
Could be the cable itself or the cruse contol mod (near the speedo gear) that bolts in the tranny...
Old Dec 21, 2008 | 09:16 AM
Jfsram's Avatar
Jfsram
Look at the cable. If there are no sharp bends in it then it probably just needs to be lubricated.
Disconnect either end. Pull the inner core out. Clean it. Lube it and reinsert. In the last 1/2" rotate it back and forth 90 deg. until it seats into the drive.
Then drive it 35mph and report back.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
articman
Jun 21, 2018 11:45 PM
firecoyote
Sep 27, 2015 02:37 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
