How to get more horsepower from my 302...
I just pulled the engine out to change head gaskets and paint the engine. Since the heads are off, what else should i do to prevent further wear?? I mean what would you guys do? The compression on all cyl are 145-155 and oil pressure is good!
Also, what small mods could i do in order to gain more horsepower?
let me guys know your thoughts....
2)you could have the heads milled to bring up compression slightly, make sure p/v clearance within spec
you could upgrade or change ratio of the rocker arms?
get a better intake manifold and some headers. maybe a bigger cam too. No sense doing anything to the heads if you dont have the parts to support them. High flow heads are a waste if your intake cant flow anough air to them.
01-06-2016 07:03 PM
09-18-2015 12:25 PM
Other Professional Racing
09-10-2015 11:41 AM
