Rough running
Old Dec 25, 2008 | 02:18 PM
saleen699's Avatar
saleen699
Default Rough running
Got a 2001 Saleen supercharged. Had it for 8 years and it came from Saleen. Low mileage with 18k. Living in Texas and had the battery on a tender with some cold weather. Took it out today and ran fine then started to idle rough and shut down. Finally got it started but it is not running smooth at all. Could it be a water/gas problem ?
Old Dec 31, 2008 | 05:26 PM
saleen699's Avatar
saleen699
Default Rough Running Update
Here is an information update. After changing out the fuel filter and fuel pump relay we found that the fuel pump was clogged up at the inside strainer/filter. This was located on the fuel pump assembly. Car runs perfect now with normal boost readings at 10-12 pounds. Will now monitor and add a fuel additive going forward!.............
Old Dec 31, 2008 | 06:13 PM
Obsequious1's Avatar
Obsequious1
Problem solved....Glad I could be of assistance...LOL
2007StangV6
Jan 28, 2016 06:09 PM
heslekrants
Sep 23, 2015 04:02 PM
musnicki
Sep 23, 2015 07:11 AM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
zanemoseley
Sep 6, 2015 12:58 PM
