Sponsored by:
Sponsored by: DashLynx
Vibrating CLutch Pedal. Please Help
Old 06-08-2005, 02:16 AM
megaforcer
megaforcer's Avatar
Default Vibrating CLutch Pedal. Please Help
Hey all,
I am a newbie here. I just got a 2002 Mustang V6 with a 5spd. I have one problem with it. The clutch pedal is vibrating when I push it in the first half an inch and there is a little squeaking coming from the engine compartment when it’s pressed that half an inch. When I go all the way down its fine. The tranny shifts through all the gears and the clutch seems to be ok, not grinding, not too high, not too low. What could be the problem? The car has 60000 miles on it. Is the clutch going or its something simple? Let me know guys. Thanks for your help in advance.
megaforcer is offline
Old 06-08-2005, 02:41 AM
MikeHawke
Retired MF Moderator
MikeHawke's Avatar
Default RE: Vibrating CLutch Pedal. Please Help
sounds like a throw out/release bearing.
MikeHawke is offline
Old 06-08-2005, 02:52 AM
megaforcer
megaforcer's Avatar
How hard it is to replace it and how much it will cost me? Any ideas? Thanks for the help.
Old 06-08-2005, 01:35 PM
MikeHawke
MikeHawke's Avatar
the bearing is only about $35 but a Ford dealer will charge you over 3 hours labor to re & re the tranny.
Old 06-08-2005, 06:43 PM
Ezrider
Ezrider's Avatar
personaly that sounds more like a warped cluch disk. throw out bearing would do it the entire time the cluch was disengaged and would have an constat loud squeeling sound. it sounds like the transmision will have to be removed and while its out you would be smart to replace everything not just the dammaged part, the parts are cheep compaired to the labor cost of the re-re, my estimte would be your looking at 4-500 to have a shop do it
Ezrider is offline
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: Vibrating CLutch Pedal. Please Help
