stock gt horsepower help
how is that making up numbers? a nitrous system with all the goodies to make it safe to run on a stock engine
zex wet kit (the best kit imo) $598
Bottle Warmer $129.95
Purge kit $108.95
Window Switch $168.95
Fuel pump 190lph (atleast) $155
Remote Valve Opener (if You need) $233.95
Already all that is $1563.75 and thats with out a tune so yeah about 1600 and for that much you might as well go h/c/i which will not add 100hp to the car but it will be safer/cheaper then nitrous. but hey by all means just get a nitrous kit and push 200 shot and then pick up the pieces later...
Purge kit $108.95
Purge kit $108.95
Purge kit $108.95
im just making a point that you have to spend to play, yeah you can pull a 125-150 shot to make 100rwhp but for how long for that you need all the goodies and hci will prob not make 100hp but close for maybe cheaper or the same price as nitrous im just saying you have to spend money to make 100hp the whole doctor thing was for ****s and giggles man
Here's the cheapest way, you'll need the following parts:
1. Adjustable Power Band - $249.95
http://kalecoauto.com/index.php?main...products_id=30
2. Engine Oil Bypass Kit - $49.95
http://kalecoauto.com/index.php?main...&products_id=8
3. High Flow O Pipe - $99.95
http://kalecoauto.com/index.php?main...&products_id=2
That should easily add 100+ hp for around $400
