Leaking differential
Old Mar 21, 2009 | 03:55 PM
mudvayne1's Avatar
mudvayne1
Mine was leaking from the cover as well. Go buy a 12 dollar gasket at advanced auto get yourself a socket and undo all the bolts on the rear end let it drain into a pan. clean where the gasket goes. I'd also check the guts to see if there are any wear on your gears. Put the gasket on, put the bolts back in. Tighten them up, Take your plug out of the front (all you need is an extension) You can reuse the oil from your pan. It won't hurt nothing. Or just get a bottle of rear end oil. To me it doesn't matter what kind it is.
I had to do that to my 95. Your mechanic was trying to screw you. It's a pretty simple job.
Old Mar 21, 2009 | 03:56 PM
mudvayne1's Avatar
mudvayne1
Double post FTL
Old Mar 21, 2009 | 05:25 PM
Gary H's Avatar
Gary H
Originally Posted by Lowtryx
This, however doesn't usually apply to Stangs as, to the best of my knowledge most/all of them (At least, newer models) do not feature this vent. Hence, why I feel you're half right
Actually, they do have a vent. Thats what holds the distribution block for the brake lines.
You'll need friction modifier as well as gear oil. Trac loc in all the mustangs.
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
UrS4
Oct 3, 2015 06:23 AM
KingRando
Oct 2, 2015 08:06 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
