2005 v6 How do you remove front bumper
Old Mar 26, 2009 | 06:41 PM
krysiewicz's Avatar
krysiewicz
Default 2005 v6 How do you remove front bumper
Im going nuts Ive removed the 3 screws around each wheel well and the 2 bolts on the top. It still feels tight and I dont want to crack it how do you it remove the bumper?
Old Mar 26, 2009 | 06:53 PM
Doogie65's Avatar
Doogie65
Did you remove the front inner fender well and remove the 3 nuts that are aligned with the seam (just outside and above the turn signals). And for GTs, you also need to remove the lower splash shield.
Old Mar 26, 2009 | 06:59 PM
krysiewicz's Avatar
krysiewicz
do you mean under the head lights ive only removed a total of 6 screws that are in the wheel well and the 2 bolts I have not removed the headlights at all or anything Do I need to do that?
Old Mar 26, 2009 | 07:30 PM
Doogie65's Avatar
Doogie65
Not sure if the V6 mounts different, but here's a bunch of front bumper files that should help you understand what needs to be removed.
http://forums.bradbarnett.net/showthread.php?t=471749
3.73-11's Avatar
3.73-11
hey man you need to remove the 3 wheel well screws on each side then peel back the splash shield and you will see 2 10mm nuts on each side up near where the bumper gap is, once you remove those on each side and the 2 10mm nuts on top near the headlights pull down on each side in the wheel well area to get it off then the bumper will come off be sure to unplug your turn signals and if you can have someone help you so you don't drop it on the ground etc
Ben
Old Mar 26, 2009 | 08:20 PM
krysiewicz's Avatar
krysiewicz
thanks its kinda dark now but im going to take care of it tomorrow thanks
Old Mar 26, 2009 | 08:31 PM
3.73-11's Avatar
3.73-11
cool your gonna love that lip man it totally changes the front&overall aggressiveness of the car
bjdutch2005
Mar 24, 2017 03:38 AM
svink32
Jul 21, 2005 01:31 PM
JoeB18R
Apr 7, 2005 06:09 PM
Duffs302
22
Sep 21, 2004 11:58 AM
