idle problems
Old Apr 7, 2009 | 08:37 PM
roushracer2003's Avatar
roushracer2003
Default idle problems
I have an 03 sohc 4.6. i recently installed long tubes and an off-road x pipe. I hooked my o2 sensors back up properly and also added MIL illiminators to the rear sensors. My car ran fine for about a week then an engine light came on. here are the codes it gave me. po443, p1451, po133, po135, po141, po155, po165, p1409, po136, po156, p1151. i purchased new o2 sensors since this fixed this same problem i had on my other mustang, but it did not in this case. all ground wires are hooked up. has anyone delt with this problem?? thanks for the help.
Old Apr 8, 2009 | 04:31 PM
96GT34's Avatar
96GT34
do u have extensions to hook the back o2 sensors back up??
i could be wrong but since the front sensors are getting an actual reading and the rear r getting a set reading, those readings may be contradicting themselves
cauing the computer to notice something is wrong setting the DTC's
again i've never had this happen so maybe im completely wrong just thowing my 2 cents out there
Old Apr 9, 2009 | 05:15 PM
roushracer2003
yes all o2 sensors are properly hooked up, yes all grounds are hooked up.. the only thing i can think of is a new maf sensor, but im not realy wantin to spend the $$ jst to find out its not the problem. is there anything else that could be causing this idle and MIL/DTC problem besides a bad intake sensor??????
once the codes are cleared, when i start my car it still idles bad, but no MIL light will come on, the codes wont pop up till the 2nd time i start it.
Old May 12, 2009 | 08:55 PM
roushracer2003
dont worry i figured it out.
Old May 12, 2009 | 09:01 PM
jwog666's Avatar
jwog666
what was it?
Old May 18, 2009 | 12:41 AM
roushracer2003
someone ****ed with my car and pulled a fuse. it was completely missing, not just blown. pretty sweet.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
