2004 a/c issues
Old Apr 27, 2009 | 12:13 PM
04stang805's Avatar
04stang805
Default 2004 a/c issues
have a 2004 mustang a/c blowing out hot air. have checked compressor, freon, and lines are clear. any input appreciated.
Old Apr 28, 2009 | 12:17 PM
yellowjacketfever's Avatar
yellowjacketfever
you have no leaks that you no of.. in a gm settup we have a expansion valve. it is a little cone shaped filter that traps metal from the pump and anything else. sometimes it will stop up and no freon will move past it... think of it as a fuel filter stopping up and the engine dies. it the same with your ac. if it is full to the recemended amount, then it should flow and cool. to much coolant and the compressor will not be able to pump. as to much pressure is created inside the lines. not enough coolant and it will not cool. it has to be in a green area or ok zone. but i am not for sure if ford uses this settup or not. did you fill it yourself or have it done. if you did it then make sure the compressor is engageing. if so then try letting out some of the freon, not suggested to do that as it is against the law. but try to get the pressure down and it might starting getting cold. hope this helps a little.
Old Apr 28, 2009 | 04:23 PM
945LSTANG's Avatar
945LSTANG
you sure you didnt miss something? how can the a/c system check out fine and yet all it blows out is hot air?
vargas
Jun 17, 2017 12:17 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
SteelerNation82
Sep 16, 2015 07:11 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
