Radiator
Old May 7, 2009 | 07:54 PM
86GT5.0LHO's Avatar
86GT5.0LHO
Default Radiator
I just put in a heavy duty aluminum radiator, water pump and 180 thermostat. No leaks. I drove the car for about 25 min, and came back to the house, when the radiator was overflowing from the insert by the cap. whats that mean? any help. I checked the thermostat is correct. and installed right. anything else?
Old May 8, 2009 | 12:04 AM
Jfsram's Avatar
Jfsram
"Insert by the cap"?? Explain
Is the system purged of air?
Old May 8, 2009 | 07:08 AM
86GT5.0LHO's Avatar
86GT5.0LHO
there is a small rubber hose by the lid that leads to the overflow tank. but I dont have a overflow tank. so the pressure and coolant flows out when hot.
Old May 8, 2009 | 11:01 AM
Stepman's Avatar
Stepman
Sounds like you got an air pocket in it. Did you fill it, run it up to temp, (when the therm opens) and fill it the rest of thee way? If not, that's what you need to do.
Old May 10, 2009 | 08:54 AM
Jfsram's Avatar
Jfsram
That is totally normal. Your radiator is designed to work with an overflow. This will allow the coolant to expand and run into the overflow. When it contracts it sucks it back in.
Your present set up is expanding, which is normal, and falling onto the ground. It tried to suck it back in "from a bottle" but yours is disconnected.
If you insist on running it without a bottle like they did in the 50 years ago in the 60's. Then you need to run the coolant level not filled to the top to allow for expansion.
Old May 10, 2009 | 08:58 AM
Gary H's Avatar
Gary H
Make an over flow bottle out of something, pretty easy to do. You might replace the radiator cap too if its been on there awhile.
Old May 10, 2009 | 04:45 PM
67mustang302's Avatar
67mustang302
You can't run at a drag strip without a coolant overflow can. They're funny that way, about people getting greasy antifreeze all over the track.
Granatelli Sales
Jan 20, 2020 12:34 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Beerman309
Sep 19, 2015 01:16 AM
MusicCity615
Sep 12, 2015 07:05 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
