curious on misfire info.
Old May 11, 2009 | 12:20 AM
zinsavage123's Avatar
zinsavage123
Default curious on misfire info.
I honestly have no clue if my car has this problem. How can I tell if my car is misfiring? I'm asking this because I have 67k on my 96 and I dont think the coil pack or plug wires have ever been changed is it time? I got the car used at the time with 47k on it. also I have bosch platinum ir fusion plugs and was told to get rid of them is this true? if so what brand to get?
Old May 11, 2009 | 01:29 AM
JC316's Avatar
JC316
You will be able to feel a missfire. While driving, it feels like the car is jerking, almost like a fish on a line and at idle it will shake. Plus your OBD2 computer will fire off a general misfire code resulting in a check engine.
The wires probably need to be replaced at this point. Some say 100K, others say 50K, but 13 year old wires can't be good. Coil pack should be fine. I wouldn't worry about it unless it goes out.
Old May 11, 2009 | 02:51 AM
zinsavage123
how bad of shake? cause when i start the car it does slightly rumble a tad for 5-10 seconds nothing major. Or that could be because of my pulleys? some say atleast. My mods are in my sig if that means anything.
Old May 11, 2009 | 01:34 PM
JC316's Avatar
JC316
No, it will do it constantly at idle. You would be able to see the motor rock slightly when it misses. The exhaust note will change, the steering wheel will shake slightly when it happens.
daltron
Apr 28, 2016 08:10 PM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
2016PP
Sep 23, 2015 09:51 AM
bconboy
Sep 21, 2015 12:52 PM
