Air Flow
Old Jun 26, 2005 | 02:48 PM
95stangergt's Avatar
95stangergt
Default Air Flow
thinking about getting an air intake but i dunno what to get. any advice? worth it?
Old Jun 26, 2005 | 04:21 PM
92hatchLX's Avatar
92hatchLX
Default RE: Air Flow
Don't get a cold air intake, it isn't worth it. Get a K&N panel filter, remove the mesh screen in your MAF, and remove your air silencer. Also if you have the equipment go ahead and cut a larger hole in your fenderwell, you can use a sawz-all or something like that. CAI are mostly used for the sound that they produce and eye candy, other wise the stuff that I just told you to do can flow just as much and sometimes more than a CAI, and plus everything up there, besides the K&N, is free stuff that you can do.
Old Jun 27, 2005 | 01:46 AM
fordguy17's Avatar
fordguy17
what he said. aluminum cai can heat up and heat the incoming air.
Old Jun 27, 2005 | 03:02 AM
razarr69's Avatar
razarr69
yeah they look sweet but id go wit tha other dudes. wus tha air silencer n where is it? i got a CAI n i wanna take it out, n how do i take tha screen outta my mass air flow sensor?
Old Jun 27, 2005 | 10:19 AM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
well you have to remove the MAF to install your CAI so reverse the process and the screen will fall out of the MAF when you remove it. it is circular....
Old Jun 27, 2005 | 11:04 AM
Chopper's Avatar
Chopper
If you remove the screen,be sure to replace the rubber gasket that is around it or you will cause an unfiltered air leak.Just pull it off the original screen and replace it in the intake.
Old Jul 2, 2005 | 02:10 AM
95stangergt
so then what is the next upgrade i should do for my car?
Old Jul 2, 2005 | 04:02 AM
PipsBlackStang's Avatar
PipsBlackStang
Well a Supercharger of course!
Old Jul 2, 2005 | 10:57 AM
stanglx2002's Avatar
stanglx2002
ORIGINAL: 1991_5.0_Convertible
agreed
as for your next mod what do you have done to the car
daltron
Apr 28, 2016 08:10 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
