Need help with Ignition
Old Jun 16, 2009 | 02:37 AM
kat83's Avatar
kat83
Default Need help with Ignition
I went to start the car like normal but when I turned my key in the ignition the key lock cylinder rotated very loosely and went beyond the normal range that I usually feel. Normally when I start my car it goes to a certain point and the engine starts, but this time the engine did not start. The battery and all of my electrical devices were engaged, but the engine ceased to start. I could also not shut off. Ive been told its some spring to plastic piece that might of fallen out of place. Does that sound like it could be it. If so how would I go about getting a guide on how to fix that. Please help.
Old Jun 16, 2009 | 08:01 AM
Obsequious1's Avatar
Obsequious1
Welcome to MF's
Sounds to me like you need to start taking your steering colum apart. It would probably be easier to replace the whole colum with a junk yard one if thats what you need.
Old Jun 16, 2009 | 01:38 PM
kat83's Avatar
kat83
How would i go about getting some kind of detailed instructions or or an outline of how to take apart the steering column???
Old Jun 16, 2009 | 02:34 PM
officer_nasty's Avatar
officer_nasty
Default Same thing happened to me about a year ago.
I got a 96 mustang gt and had the same problem. All you need is a plastic thing that you can buy at ford for about 7 to 10 dollars. Your going to have to take you steering wheel off to do it, but if you want to see the problem just disconnet the plastic covers around the steering wheel to see the problem. You can see the problem from above the wheel and if you stick your head under the wheel you can see where it's disconnected when you move your key back and forth.
If you want to know how to disconnect the wheel you can buy a repair manual or just ask someone to do it. Make you sure it's done correctly because someone can jack up your air bag.
Old Jun 16, 2009 | 03:30 PM
mudvayne1's Avatar
mudvayne1
Just adding to this. If you ever need to work on your airbags disconnect the battery. Airbags aren't cheap and you don't want the crap knocked out of you trying to take a steering wheel off.
Old Jun 16, 2009 | 03:58 PM
kat83's Avatar
kat83
Thanks for the help guys. I went and bought a book from autozone, and I have someone who is a lot more handy when it comes to cars. we are starting to work on it now. Wish me luck...
Old Jun 17, 2009 | 01:37 PM
kat83's Avatar
kat83
[B][B][B][B] Same thing happened to me about a year ago.
I have taken the steering wheel apart and can see the plastic thing your referring to. But any idea what that part is called. Plan on contacting Ford today to get that part ordered. Thanks.
bradleyb
Nov 27, 2015 07:50 PM
piotrek53
Oct 13, 2015 06:54 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
jessicarabbit
Sep 25, 2015 12:41 PM
Wombatnation
Sep 13, 2015 09:16 PM
