Rear suspension creak
Hey guys,
Once my car has warmed up, and especially after a bit of aggressive accelerations and braking, I get creaking noises in the rear - sounds like driver's side
too. It's only in the first two gears, but it's worse in 1st than second. Basically after to a stop, I'd start accelerating and the creaking would be there under initial acceleration. It would also be there if, say, I stayed in first or second gear and just let off the gas (the load on the car would shift). Also, it happens when taking a corner in 1st/2nd gear, but not as loud.
What do you guys suspect is at fault?
Thanks in advance
Thanks in advance
musnicki
09-23-2015 07:11 AM
09-08-2015 11:50 AM
