stoplight switch- brake light
Old Jun 28, 2009 | 08:13 PM
sfi's Avatar
sfi
Default stoplight switch- brake light
Has anyone changed a stoplight switch. this is the electrical switch when you push on the brakes, it activates your brake lights and Im sure some other things. Reading the directions it seems kinda staright forward, though IM not good w/ electrical and soldiering. ANyone done this and have any advice
Old Jun 29, 2009 | 10:24 PM
donhall's Avatar
donhall
Default stop lamp switch
Simple job to replace switch. Unplug electrical connector (no soldering required) and rotate switch counter-clockwise 45 degrees to remove it. Install new switch in reverse order. NOTE: The switch is self-adjusting. Initial installation of the switch allows for one adjustment. If additional adjustments are necessary, you will need a new switch.
GimpyHSHS
Sep 18, 2015 12:27 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
amandahchase
Sep 3, 2015 10:09 AM
