98 GT running lean
Old Jul 6, 2009 | 12:46 AM
jonschristie's Avatar
jonschristie
Default 98 GT running lean
Hey everyone, this is my first post on the forums, so thanks in advance for all the help I'm sure I'll get!!
I just bought my first Mustang, a 98 gt. I'm having trouble starting it. It takes a while for the engine to start, and when it does, it sometimes runs at very low rpms for a couple of seconds. Once I get it started though, it runs great!!!
The problem was starting to bother me, so I borrowed an Innova code reader, and came up with these two codes (the check engine light is on btw) P0174, P0179 (system too lean, bank 1 and bank 2). Any ideas of what I should try first?? I'm thinking fuel filter would be the easiest and cheapest... Thanks for the help!!!!
Old Jul 6, 2009 | 12:55 AM
socalwrench's Avatar
socalwrench
Well, a clogged fuel filter or failing fuel pump can cause a lean condition. However, failed oxygen sensors can as well. I would also check the condition and cleanliness of the mass air flow sensor.
Old Jul 7, 2009 | 02:22 AM
jonschristie
So I cleaned the MAF sensor, and that didn't really seem to do anything, so tonight I replaced the fuel pump. That helped a little, but the car still has trouble starting, and when it does, it seems like it's choked for a few seconds... Any other ideas??
Old Jul 7, 2009 | 02:54 AM
JC316's Avatar
JC316
Fuel Filter? I had these same codes with a bad O2 sensor.
Old Jul 7, 2009 | 10:03 PM
Lowtryx's Avatar
Lowtryx
+1 on Fuel Filter. If you have the means to change the Fuel Pump so easily, a Fuel Filter should be no problem. Be sure to install properly, Fuel Filters are directional. Should be an FL-986B I believe. Look for the Arrow on the filter housing, it will point in the direction of the flow towards to engine.
Old Jul 9, 2009 | 12:45 AM
jonschristie
I'm sorry guys, I accidentally put fuel pump instead of fuel filter. I replaced the FILTER... my bad... Tonight I was driving the car, and it had very little power... like it just lost everything. I know for a fact the car is running lean. Should my next step be to change the fuel pump, or should I try something else first??
Thanks, and sorry for my typo...
Old Jul 9, 2009 | 10:47 PM
JC316's Avatar
JC316
Um, cheapest and easiest first. Do the O2 sensors. It's pretty common for them to go out. Also, reset your codes after changing any part out.
Old Jul 10, 2009 | 11:55 PM
jonschristie
Hey everyone, thanks for the help. I ended up changing out the fuel pump assembly, and it runs like a beast!!!
Jb145700
Aug 21, 2022 06:37 AM
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
uedlose
Sep 10, 2015 03:30 PM
