High beams or regular..?
Old Jul 15, 2009 | 11:20 AM
secuono's Avatar
secuono
Question High beams or regular..?
03 standard mustang, there is a light in the middle that lights up when i turn on my lights. Kinda looks like a sideways moving jellyfish. How do you turn on the highbeams/lowbeams? The **** you can pull to three points. First is the panel lights, then I don't know(nothing happens, and last the lights turn on. Any clue what is going on? Thanks!
Old Jul 15, 2009 | 11:24 AM
GreyStang's Avatar
GreyStang
Push the turn signal lever away from you (towards the dash) to get high beams..
Pull the lever towards you to <flash> the highbeams if U want to signal someone
Old Jul 15, 2009 | 12:24 PM
secuono's Avatar
secuono
When I try to turn the high beams on, the right light turns on then flickers and turns off, the left doesn't turn on at all. when I pull towards me, again, right turns on for a second and then off and the left does not turn on, if I try doing that again, it doesn't work. The reg. lights work fine. Though they do need a second to turn on all the way. The are HIDs if that makes a difference. What is wrong now with them?
Old Jul 15, 2009 | 10:39 PM
demighost's Avatar
demighost
you might have single beam hid's. Where there is no high beam you could potentially damage your hid's so check to see what they are before attempting to use it.
CS2007
Jun 25, 2019 09:45 PM
Drastang
Sep 30, 2015 03:48 AM
mungodrums
Sep 28, 2015 10:54 PM
PNYXPRESS
Sep 14, 2015 09:50 PM
