Engine Identification
Old Jul 15, 2009 | 09:23 PM
avsman's Avatar
avsman
Default Engine Identification
Hey! I recently bought a 67 mustang that is in need of repair. Unfortunately the dealer didn't have a clue what the engine was. Many friends say it is a 289, but one said there is a chance it could be a 302. So I am trying to figure out what one it is. Can someone please tell me where the correct code on the engine is, there are three different ones and I can not identify the right one. Thanks for reading.
Old Jul 15, 2009 | 09:53 PM
koesterca1's Avatar
koesterca1
What are the casting numbers you can read? If they start with c6xx or earlier it should be a 289..c7xx or c8xx could be a toss up between 289 or 302 as the assembly line was moving towards the 302..c9xx or later should be a 302..they are basically the same motor with different stroke hence the extra cubes on the 302..this is all assuming the motor is original and someone hasn't pieced together a Frankenstein motor from different years of parts.hell even the factory did this at times using parts available..depending what parts you need most should be interchangeable.
Old Jul 15, 2009 | 10:25 PM
avsman's Avatar
avsman
Thanks for the advice
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
