Drag racing with cold start
Old Mar 16, 2010 | 01:41 AM
SXGT's Avatar
SXGT
Originally Posted by SideSwipe
Good thing i dont go above 2500 rpms until at normal running temp
O_O i stay under 2K RPMS all day or until driving on the interstate.
Old Mar 16, 2010 | 11:39 AM
GreyStang's Avatar
GreyStang
Originally Posted by SXGT
my ET was a LOT faster with a cooled engine.
Ok but don't you care for engine longevity?
Old Mar 22, 2010 | 08:26 PM
ga chopper's Avatar
ga chopper
always warm her up never jump in start hammering it
Old Mar 22, 2010 | 08:27 PM
ga chopper's Avatar
ga chopper
newer car are programmed to run better at first start up but its always better to get her warm.
Old Mar 24, 2010 | 02:05 AM
hiboostwoody's Avatar
hiboostwoody
Computer controlled cars never run at optimum performance levels when they are cold because the computer is in open loop.
Just to throw this out there and it has absolutely NOTHING to do with car engines. If you start a liquid cooled 2-stroke engine when it is cold (like down around freezing) and immediately hammer on the throttle, you risk a good chance of the piston sticking in the bore. It's what is known as a cold seize. The reason it does this is because the piston expands faster than the liquid cooled cylinder. This is espescially common if the tolerances are a little on the tight side. Usually once it cools back down the piston will shrink back down and you can turn the engine over and restart it. How's THAT for some totally useless information?
drfister
May 3, 2018 10:38 PM
Spiral534
Oct 6, 2015 04:31 PM
Sep 8, 2015 04:35 PM
Milan Dragway
Aug 12, 2015 03:43 PM
