Auto to Manual
Old Jul 5, 2005 | 09:50 PM
95stang5.0's Avatar
95stang5.0
Default Auto to Manual
Well as some of you know my tranny is slipping and is gonna need to be replaced or re built i figured since i would have it all apart i might just throw in a manual ifi its not to difficult. If i buy the manual tranny- shifter-and clutch. Do i just replace the tranny with the new one install clutch and shifter and all the wires? Is that all i need or is it alot more difficult than that. Has any one had any experience doing this and how much do you think a shop would charge? Thanks in advacne
Old Jul 5, 2005 | 11:57 PM
cammedlx's Avatar
cammedlx
Default RE: Auto to Manual
You will need the following:Clutch pedal assl.,tranny,crossmember,t-5 drive shaft yoke,bell housing,flywheel,clucth kit,shifter,and possibly and 5 speed ECU.Also 5 spd. shifter bezel and shift boot if you want it to look ok instead of just thrown together.
Old Jul 6, 2005 | 02:08 AM
94Cbra's Avatar
94Cbra
My sugestion would be to just install a shift kit/stall on a rebuilt auto. Built autos are nasty.
Old Jul 6, 2005 | 03:13 AM
Raven_pbr's Avatar
Raven_pbr
Don't shift kits kill the tranny life though? I mean you'll be rebuilding it again in no time if you just throw a shift kit on?
Old Jul 6, 2005 | 01:01 PM
99saleen351r's Avatar
99saleen351r
shift kit can make your tranny last longer.The worst thing for an auto is slow soft shifts cause it burns the belt every time it shifts.You want it to shift hard and fast to last.If your gonna rebuild the auto I suggest you get a stall converter also cause the stock stall sucks.
BeatnikFink
Oct 1, 2015 08:00 PM
fastbackford351
Oct 1, 2015 12:24 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
2poor4u2
Sep 26, 2015 11:08 AM
