car does not start
Old Jul 7, 2005 | 08:02 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: car does not start
Doesn't make any sense to just start throwing money at it without knowing what the real problem is. Quick way to test the solenoid is take a screwdriver that has a PLASTIC HANDLE, turn the ignition to on, and short accross the two big copper looking studs on the solenoid. If it cranks over just fine or cranks and catches, then you know it's the solenoid. If it does the same thing where it just clicks and nothing then you're starter may be dying or does need a heat shield.
A hot starter takes more juice to crank over, so you may want to also take a look at your battery cables and the grounding point of the negative cable. If they're corroded that could also be a problem as the corrosion adds resistance to the current.
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
msavoia23
12
Jul 7, 2018 12:08 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
