my stupid mustang
Old Aug 20, 2009 | 09:22 AM
labtec101's Avatar
labtec101
Default my stupid mustang
i changed the brake pads on my mustang and the pedal was soft so i changed bled the brakes still soft pedal goes all the way to the floor theres no air in the lines any one know what else there could be for a problem
Old Aug 20, 2009 | 11:34 AM
Jfsram's Avatar
Jfsram
If by soft you mean the car stops fine but if you hold the pedal down it slowly sinks to the floor. That's probably a master cylinder.
Old Aug 20, 2009 | 03:22 PM
ChalknCover's Avatar
ChalknCover
Sgt. Killjoy
Did you change the brake pads because of the soft condition, or did that come about after the pad change?
Old Aug 20, 2009 | 03:53 PM
labtec101's Avatar
labtec101
technically the car stops by but you can push the pedal all the way to the floor like the brakes will grab but barely you need to drive really slow when you get near a car and mostly downshift but stops and the problem occcured after the brakes were installed they were fine before just low
Old Aug 20, 2009 | 06:14 PM
Darkvinyl's Avatar
Darkvinyl
Can't imagine how air would get in the lines by just changing the pads....
Why did you change the pads?
Old Aug 20, 2009 | 06:50 PM
07 naja's Avatar
07 naja
Are you sure you have the correct pads installed, are they actually grabing the rotor.
Old Aug 20, 2009 | 06:55 PM
bigmike0405's Avatar
bigmike0405
take it to a garage dude.
Old Aug 21, 2009 | 08:58 AM
labtec101's Avatar
labtec101
I changed them because the old ones were almost gone less then 2mm and they needed replacing
i am sure they are the right pads for the car and they are grabbing the rotors i can feel them its just really weak
i took it to a shop and they guy told me that ford uses a hydraulic pump that controls the power steering and the brakes thats probably what failed and its this little black tube looking thing thats just above the reservoir and its under 10 000 psi n e one know what he is talking
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
chain
Aug 17, 2015 08:52 AM
'stangdude
Aug 12, 2015 01:27 PM
daytooday
Aug 11, 2015 09:22 AM
